I downloaded Magic fonts to my laptop yesterday, in the hope of pimping up my fonts in MS word. After downloading though, I couldn’t see it in my fonts. Did I miss out on something to do for it to show up in my MS word? Haha. Sorry. I’m really not that techy of a person. Please help? J
Are Magic fonts compatible with MS Word?
Please follow the below steps to install the fonts that you downloaded already.
1. Close all Windows applications that you have opened. Open the "control panel" and then type "Fonts" on the search box at top left corner. Then open the "Fonts" folder on your computer.
2. Then minimize that folder and open the folder that contains the new fonts that you want to install.
3. Then drag the fonts you want to install to the "Fonts" folder and drop it there. If it is installed correctly a dialog box would appear telling the new font is being installed.
If you are using older version of Windows OS please follow the following steps.
1. Open the "Fonts" folder and from the drop down list select "install new font". Then browse and give the path to where the fonts are located. Then click "OK"
