Are there any computer error flow chart that I could follow?
Hi everyone!
I am a Windows user and quite often encounters computer error. I am knowledgeable of flowcharts so I might as well understand if there is already an existing computer error flow chart. Is there any, I hope someone would give me a suggestion about this so that whenever I encounter any computer error I won't need anymore have to have the trouble of someone doing it for me.
Thank you very much.
Best Answer by Miguel Patterson
Answered By 0 points N/A #154139
What specific type of Windows OS you want to troubleshoot? Because as far as I know every Windows product has what they call the MSDN library which is an essential source of information about a specific product. It usually contains error handling and troubleshooting tips. Plus if you really need a computer error flow chart? What specifically error you want to troubleshoot? So that, I might help you.
Answered By 0 points N/A #154140
Hi Labasaan,
Computer error flow charts are meant to help you solve or understand some of the problems or errors you are encountering with your computer.
You can decide to go online to the following website http://www.fixingmycomputer.com and follow the online totally free computer repair flow chart. You follow the step by step instruction in the flow charts to get a guideline to fixing your problem.
You can also try the second option which involves you purchasing a windows advisor application. You can also get your 6 days free trial so that you can  experience it before purchasing it simply  follow the steps in the instructions manual of the windows advisor checklists to trace the root cause of  your error and how to resolve it.
You can download it  in the following link.
https://secure.windowsadvisor.co.uk/
