Are there any new Android tablets out
I keep hearing about the iPhone 5 and Microsoft tablet as well a Mini iPad.
I still like the Androids Is there any new Android Tablets out there.
Dear,
At present no Android Tablet out. ARCHOS is released it's duel core 1 Ghz processor in the last year. It's Also released all dual-core G9 tablets with the speed of 1.5 GHz in the last year. Then the prices were:
1. ARCHOS 80 G9 16 GB-         $329
2. ARCHOS 80 G9 250 GB     $369
3. ARCHOS 101 G9 16 GB     $399
ARCHOSÂ 101Â G9Â 250 GBÂ Â Â Â Â Â $469
Thank you.
Dear User,
They are many Android tabs which you can refer to.
And here are the few of them. The best android tablets in the world.
1. Google Nexus 7.
2. Asus Eee Pad Transformer Prime.
3. Samsung Galaxy Tab 10.1
4. Asus Eeepad Slider.
Thank you.
If you want to know about some new tablets, you would want to check Samsung Galaxy Tab S6. The Samsung Galaxy Tab S6 is a 4G tablet operating on 2G, 3G, and 4G network bands using GSM, HSPA, and LTE technologies. It was announced to the public on July 2019 and released on August 2019 measuring 244.5 x 159.5 x 5.7 millimeters and weighing 420 grams.
It uses nano-SIM card and built with front glass and aluminum body with stylus (Bluetooth integration; magnetic). It has Super AMOLED capacitive touchscreen display with 16M colors at 1600 x 2560 pixels screen resolution.
It ships with Android 9.0 Pie with One UI powered by 7 nm Qualcomm SDM855 Snapdragon chipset, Octa-Core processor (1 x 2.84 GHz Kryo 485, 3 x 2.42 GHz Kryo 485, and 4 x 1.78 GHz Kryo 485), and Adreno 640 GPU. It supports microSD expandable up to 1 TB.
It is available in two memory capacities: 6 GB RAM with 128 GB internal storage and 8 GB RAM with 256 GB internal storage. The primary camera is dual camera: first camera supports 13 megapixels with f/2.0, 26mm (wide), 1/3.4″, 1.0µm, and AF; second camera supports 5 megapixels with f/2.2, 12mm (ultrawide), and 1.12µm featuring HDR and panorama. It can record video in 2160p at 30 fps.
The secondary camera supports 8 megapixels with f/2.0, 26mm, 1/4.0″, and 1.12µm and can record video in 1080p at 30 fps. It doesn’t support 3.5-millimeter jack. It has Wi-Fi 802.11 a/b/g/n/ac with dual-band, Wi-Fi Direct, and hotspot support; Bluetooth 5.0 with A2DP and LE support; GPS with A-GPS, GLONASS, BDS, and GALILEO support; and USB 3.1 Type-C 1.0 reversible magnetic connector.
It has built-in fingerprint (under display, optical), accelerometer, gyro, proximity, and compass sensors with Samsung DeX. It runs on non-removable Li-Po 7040 mAh battery featuring 15W fast battery charging. It is available in Mountain Gray, Cloud Blue, and Rose Blush colors.
