Are there any other Corel products that cater to web graphics?
I came across the Corel Draw Graphics Suite X5 SP3 15.2.0.686 Multi LANGUAGE.
If you need an application from Corel that caters on web designing, you may consider trying Corel Website Creator X6 which is a powerful website design software. Corel Website Creator X6 works with Windows XP [Service Pack 3], Windows Vista, and Windows 7. This application doesn’t require faster or higher processor and can work with at least a Pentium 3 660 MHz. It only requires at least 512 MB of RAM and needs only 250 MB of your hard drive space. This application also requires installing of Adobe Flash Player 9 or later versions. This version costs $199 but you can also download it as a trial version.
To download Corel Website Creator X6, you may visit COREL — Website Creator X6.
