I am working in the IT section in the government office. Most of the PCs only functioning backup system is floppy drive. When reinstalling the operating systems it is really difficult to find drivers again. So is there any small software that can backup the system driver that can run on floppy disk?
Thank you.
Are there any small programs for floppy disc to backup system drivers?
Hi
Floppy disks have very limited space. It is not possible to save the entire driver backup in such a small space. |But you can store drivers of old devices or standard devices they usually have small size drives Also Floppy damages and corrupted very easily so it also not robust mean of storing information. You should use some other means.
Thank you.
Now a day’s floppy disk users are rare because it contains very short space. You cannot stock software in a floppy disk drive. It is sufficient for text document. But if you use the zip format then it can help you a little bit. You can use the Winzip software to convert anything in a zip format.
