Me and my team have been using lotus for our files and now we want some of it to be exported to QuickBooks for easier monitoring of our transactions. Are there some ways to export lotus to QuickBooks? I would really appreciate your help on this.
Thanks!
Are there any ways to Export lotus to QuickBooks?
I think with this problem since the file needs to be transformed or converted to a different format which is from Lotus Notes to QuickBooks then you must try Full Convert Enterprise. It is a fast, powerful, and easy to use database converter. With this application, you can convert between these database formats:
Source databases
Access
CSV
dBase
Excel
Firebird
FoxPro
Interbase
MySQL
Oracle
Paradox
Postgres
SQL Server Compact Edition
SQL Server
SQL Server Express
SQL Azure
XML
+ many more via ODBC
Target databases
Access
CSV
Excel
Firebird
Interbase
MySQL
Oracle
Postgres
SQL Server
SQL Server Express
SQL Azure
XML
To try Full Convert Enterprise and to download it, you may visit Spectral Core — Full Convert Enterprise. This version works with Windows .NET Server 2003, Windows 2000, Windows 2008, Windows XP, Windows Vista, Windows 7, and Windows 8. It has a free-trial version and if you wish to buy it, it offers a 30-day money-back guarantee.
