Are there available sound recorder driver windows 7?
Hi to all! I am searching for some available sound recorder driver windows 7 that i can download or install in my laptop. I seem to get a problem on saving audio files in windows 7 premium.
Sound Recorder is easy-to-use program software that allows you record sounds and save the soundtrack straightly into WMA, WAV, or MP3 files. It is a perfect for your own music, voice or any sound. It supports streaming audio from the Internet, external devices as well as other software like Media Player and Winamp. The recorder creates high excellence recordings in saving audio files. You can choose sound recorder at download.cnet.com.
Best regards,
Heather marie
Windows 7 allows you to record your own sound. It’s possible and you can do it whenever you want. Windows 7 has sound recording option. You can record you own sound and other sound with the help of your microphone.
Go to start menu.
Type ‘sound recorder’ on search bar.
Then sound recorder function will appear.
Record your sound through the microphone and enjoy.
