Are there techniques to use iPhone 4S with a longer battery life?
IPhone really has a shorter battery lifespan when you use your device all the time. But surely, there are ways on how to extend it.
1. Lower the brightness of the screen or you can turn the Auto-Brightness ON so that it will only consume less power when the surrounding has more light.
2. Keep Bluetooth off when not needed.
3. Turn 3G and Cellular Data off when you are not using it for mobile browsing, surfing or other internet related activity.
4. Turn off Wi-Fi as well if not needed.
5. Turn off any other capability that is not needed.
6. Auto-Lock device sooner to sleep the device if no activity is being done.
7. Update software for Apple Engineers might have found a new way to increase battery lifespan.
If still not satisfied, you can buy extended life batteries such as External Mini Battery and Juice Packs.
I’m not sure if there is indeed a special technique or method that a user can use just to prolong the life of the phone’s battery. There are actually some things you can do for your phone to make the life of the battery stay a little longer. If you are located in a slightly colder place, your battery’s life will deplete a little faster. It can’t stand low temperature and the effect is the rapid decrease in its stored power. In this case, I think the only solution is to keep the phone in a warmer place.
You can also turn off your phone’s Bluetooth connectivity if you are not using it to reduce power consumption. Keeping the Bluetooth active gradually decreases the life of the battery. And this also goes with the phone’s Wi-Fi connection; turn it off if it is not being used to reduce power consumption. Constantly connecting your phone to the internet even if you are not using it rapidly decreases the life of the battery. You may also shorten the duration of the screen’s backlight to conserve more power. You may also want to avoid playing too much game with your phone because this is a great power eater. Playing a game with your phone even for a short time rapidly decreases its charge.
The battery life of any phone depends on the duty the phone performs, for example if play games, the heavier the performance the lesser the time it takes before recharging. Anyway, also check out this Techyv post too to get more information.
