Hello all,
When I try to login using GitHub account it’s a new account for Phone Gap and in the Ares accounts, I try to enter with GitHub credentials. But it is not allowing me enter with GitHub credentials, I am getting this error message.
Adobe credentials works well for me. I am getting this error because of GitHub? What should I do now? Help please.
Title: Ares IDE PhoneGap Accounts work with error
Unable to check PhoneGap Build Account
Details
Error: Unable to get PhoneGap application token (undefined
Ares accounts is not allowing GitHub credentials
This problem has been reported as a bug and was already fixed in version 0.2.3. So, if you will be downloading the latest Ares version you will no longer encounter this problem and you will be able to login to PhoneGap Build using your GitHub account. The reason why you can’t login to PhoneGap Build using the GitHub credentials is that your GitHub username and password doesn’t work on Ares and it cannot access PhoneGap Build web endpoints.
To fix this, click on the profile icon located on the upper right corner and select “Edit account”. Select “Account details” tab and click “Connect an Adobe ID”. Next, use your Adobe ID to sign in or click Create Adobe ID to create a new Adobe ID if you don’t have one yet. This should fix it.
This bug only affects Ares 0.1.2 and there’s no other solution but to login using an Adobe ID. Visit Ares 2.2.7 to download the latest version of Ares.
