Arqball Spin App for iPhone 4s
Arqball Spin App is the new application for iPhone 4s. It is developed to create and edit image in 360 degrees spins with iPhone 4s. Can this app have ability to view 360 degrees spins and edit any kinds of image like captured pictures from iPhone 4s?
Best Answer by Montefalcon Sop
Answered By 0 points N/A #133984
The Arqball Spin App for iPhone 4s creates the so called 3D model of objects that spins in front of the iPhone. It turns your iPhone into 3D scanner. You will need to record the object that is spinning 360° degrees in front of your iPhone to get the model of the object. It's not the actual 3D because you can only rotate it 360 degrees. Capturing Process takes about 20 seconds to capture and about 30 seconds to compress it. So it can not take already shot picture and make a spinning 3D model because you can't rotate already taken pictures.
Answered By 0 points N/A #133985
In this Arqball Spin Application provide you can view 360 degree spins and you can also edit any kinds of spin images.
Arqball Spin Application is used to create visualization interactive of 3D objects.
We can edit image when we capture image through iPhone 4S. Capture process takes one minute.  In this application we can easily create 360 degree video images.
You can edit captured pictures in iPhone 4S. After the capture process you can edit image. Edit the image by zoom in or outside the object.  We can't rotate 360 degree for already captured images. Arqball Spin Application is very simple to use. For further information please see below video.
