Article Over Where Is Task Scheduler In Windows 7 Operating System.
Guys I am using window 7 OS and in spite of hours of checking I can’t find the task scheduler in my system. So can anyone tell me where is task scheduler in windows 7 OS?
Task scheduler in windows 7 can be located in %SYSTEMROOT%\system32folder.
Now to run task scheduler in windows 7:
Via start menu:
1) Open start menu and go to all programs.
2) Now Click on Accessories.
3) Go to system Tools and look for task scheduler and double-click on it to run it.
Via control panel:
1) Open start.
2) Now open control panel.
3) open system and security
4) Then go to Administrative tools
5) Now execute task scheduler
Via search box:
Another simple way of finding task scheduler is just to type in the schedule and hit enter.
Via command line
1) Open the command prompt by entering cmd in the run.
2) Now after the command prompt opens type Tasked.msc
Hope this helps you.
Notifications
