Artisteer apple template crashes in Lion
I just reinstalled Artisteer apple template generator on my MacBook Pro with 2.4 GHz Quad Core i7, 8 GB DDR3 RAM, Nvidia GeForce 650M and upgraded OSx Mountain Lion.  Ever since I upgraded my OSx, the program always crashes.  It worked fine when I was still in Snow Leopard.  Can anyone help?  Thanks.
Best Answer by Drake Vivian
Answered By 40 points N/A #172911
You have changed the mind of your system and body remains that same, Then it is very obvious that it will crashes out, This could be happening due compatibility issue, Every software is design according to different system configuration, And thats why company's tend to release newer version more often than not, Now what you can do is , uninstall the software and reinstall it according to you Macbook pro configuration, It will surely work fine.
Thanks
Answered By 30 points N/A #172912
Hi there Fernando W Alvarez,
Unfortunately, at this moment, there is no official stable release of the  Artisteer apple template generator available for the Mac OSx Mountain Lion.
The only available version for Mac OSx is the beta version and it is partially working on the Mac OS 10.5. There is not much you can do about the compatibility so you can either switch back to the older OSx, run the Windows version in the virtual machine or find an alternative software till the proper MAC OSx version of the Artisteer apple template generator  is developed and released.
Best regards,
Drake Vivian
