Hi All,
I need to know about Artistic Media for Corel Draw X3, Please do the needful for providing tutorial about using the artistic media feature of CorelDraw. That will help me to have a calligraphy look and make my designs more artistic.
Thanks,
Alland Ornad
CorelDraw is a comprehensive vector-based drawing and graphic design program. To use artistic media tool of CorelDraw you need to have tutorials which would give you through every step, and to understand it completely you should follow the instructions step by step given in the tutorials. What I can do is to give you links related to artistic media tool tutorials because it has got extensive tools provided in it and it isn’t possible to write them all here.
http://www.coreldrawtips.com/
This has got hundreds of tutorials related to every tool in artistic media.
https://www.gimpshop.com/tutorials/how-to-create-a-logo
 This provides a great tutorial for logo making, guiding you through every step of dealing with different tools in CorelDraw.
http://corel.force.com/support/apex/KBArticleDetailPage?id=kA060000000L4XT&lang=en_US
This link will take you to the page containing conversion of simple text or line into state of art graphics.
