Artistic Media tool in CorelDraw X6
Hello Friends,
I am using Corel Draw X6 and is studying by my own. I need to know about, how to use Artistic Media tool in CorelDraw X6, Please do the needful for providing the detailed features and usage of the Artistic Media tool in CorelDraw X6.
Thanks in Advance,
Tomee Llman
Answered By 0 points N/A #156194
Hello Tomee Llman,
The Artistic Media tool in CorelDraw X6 is represented by that fancy creation that we all can ses in a design of a website. For using the Artistic Media tool you have to do the following:
1. After you finished your creation you can go to Effects tab and then click on Artistic Media;
2. On the opened window, you can select the Default Strokes and make yourself comfortable by playing with its settings.
You don't need to be an expert, but you need to practice if you want to handle the Artistic Media tool very well in the future.
Take care!
