ASC Pro Skins error and closed the application unexpectedly
Hi there,
ASC Pro Skins appeared on my desktop today with an error. The button with Continue application is not working at all because the program is closing immediately. Can anyone help me please with this error ? What is causing this ?
Thanks !
ASC.exe
An error occurred in the application.
Answered By 0 points N/A #178055
This type of issues are mostly related to Hard-disk problems. These issues also caused by the malware and Spyware.
You can fix it by following the steps below.
  • Run "Error checking tool" to scan the Hard disk.
  • When san is finished, try to install damaged software from the original source.
  • Download the ASC.exe file and replace it with the old file.
  • In this way you can fix the issue.
If ASc.exe problem is caused by registry issue then, there is another way to fix the error. You can use special designed "professional error repair software" Because it is risky to modify registry manually. Follow the steps below.
  • Download and install "DLL repair software" from the legal source.
  • Reboot system in safe mode.
  • To diagnose DLL error, click on the "Scan"
  • Click on "Repair" to fix the DLL error or other errors in system.
  • Now there would be no issue again.
