So, I understand that Ascertia PDF Sign and seal provides digital notarizing. When I get to a website to look into purchasing it, I found that it doesn’t allow editing. I wanted to know if this is really a good buy. Can someone help me out in understanding the pros and cons of getting PDF sign and sea? Thanks in advance.
Ascertia PDF sign and seal software
Hi there user:
As far as I can understand, editing should be allowed to this software. I think you might have downloaded an incomplete version of Ascertia PDF Sign and Seal software which gives you limits for using it. View this link, compare this version of Ascertia PDF Sign and Seal software to your software. http://www.fileguru.com/PDF-Sign-Seal/info
Thank you for asking.
Hello Edward,
PDF Sign & Seal
Its a desktop based PDF solution which focus on applying digital signature, time stamps and well designed PDF encryption to business documents.
For large and small business it provides efficiency, clarity and additional security.
It does not allow users to add or edit text in a PDF.
It does create PDF which can be viewed by Adobe Reader and can be edited in another PDF solution theoretically.Â
Hope this would help you.
Thank you.Â
