Finlay
50 points
Posted on - 01/30/2013
I want to get a software which can turn any font into a stencil per indesign, a software to create stencil letters out of any already installed true type font. I'm a Windows user. I'm ready to purchase it if that doesn't come for free.
Thanks
Asking for a software to convert any font to stencil per indesign
Your problem can be solved by installing Stencil Fonts 1.0, you will be able to convert any true type font into stencil. This program will insert apertures, so that even if you cut the letters, they will stay connected. You may print or lot the letters or export the letters as a DXF file. You may install this software from: Stencil fonts 1.0. It will look like:
