Hi experts,
Today I reinstalled my Windows 7 (x32) on my laptop and I have this error for the first time. I never had this error before reinstalling my Windows and I to think that I might did something wrong in settings when the installer was running. Can anyone help me to fix this error? Why I have this error now and can this kind of errors be prevented in the future?
Thanks!
The ASlO sample rate is not supported by one of the USB interfaces! Please check your sync settings in the Control Panel.
OK
points
ASlO sample rate is not supported by the USB interfaces.
It is a current known problem with the device drivers for M-Audio USB interfaces which affects multi-client operation. This problem may happen when you are launching an ASIO application and another application or in some cases the windows operating system, is trying to admission the device.
To solve this issue, quite your recording application and then go to the Windows “Control Panel” >> select computer’s “built-in sound card” as default playback & recording device. This will help you to use your M-Audio device with your ASIO Application. When you like to use your M-Audio device for non-ASIO applications, for example, iTunes, Internet Audio, Windows Media Player etc. Set your M-Audio device as the default playback device from the Windows Sound Control Panel.
