AspectJ Development Tool ( AJDT)
Hi all
I attempted to set up GWT in eclipse Galileo.
However I find some error messages. Here is the error message.
I need to solve this error. I need it quickly.
Please help.
Answered By 0 points N/A #148066
I think the installation that you are trying to perform on your machine has requirements that are still missing and have not been installed. For you to know the exact reason why the installation really can’t push through, check again the program’s technical specifications. It is possible that the application requires other components to be installed first before proceeding on the installation.
Since this is an installation, be sure that there are no other programs running while doing the whole procedure. Because installation procedures require the system to be updated and the process requires full access to the system files. The only solution to this is to really check and complete the system requirements of the application before doing the installation again. The installation will really not continue if there are missing components in the system.
