Hi guys. I would like to edit and modify some PDF files. I downloaded the free evaluation copy of asppdf 2. I installed and launched the program. All I see is a black screen. Could the file that I downloaded be corrupted? I'm on Windows XP 32 bit. Thanks.
AspPDF 2 program only shows black screen
The file that you downloaded could be corrupt.Did you try to download it again? If you are still having the same problem then, it could be your development environment not supporting COM or you do not have IIS with ASP.
I would suggest you to try other software's like
Foxit- https://www.foxitsoftware.com/pdf-editor/
Inkscape- https://inkscape.org/en/
Hope this helps.
Thanks,
