Assembly code for calculator with negative numbers.
Am new to programming with assembly , and am having problem with Assembly code for calculator.
I want to know how can I do arithmetic operations with negative numbers, and if anyone can provide me a simple code so I can understand better.
Thank's.
Answered By 60 points N/A #171188
Hello Derek,
I can understand your problem as assembly language is very tough. Here, I am providing you the source code to various types of calculators.
If you are looking for a simple add subtract calculator then download it from here.
If you need code for advanced calculator then download it from here.
Or you can select your own type here.
I hope it will help you!
