Hi TechyV,
I started using AnkhSVN, and I faced a strange problem.
In VS 2008 I opened a project from the subversion repository, and it successfully got downloaded to my computer.
But when I try to open the solution in VS, I get the following error?
Any solutions?
Thank you.
Source control – Unable to access database
The associated source control database could not be accessed.
Hi there user:
Just update your bindings manually.
Select all your projects. Click Browse and then Enter. That’s it. Now you’re database is well set-up. Problem solved!
Let me just give you a reminder. Sooner, you will create or load a project again. And if the error message does appear again, I can say that it could be a bug. And this time, I’d guess you already know what to do to get rid of these bugs. Run a PC scan and then download a Windows Defender.
Thanks for posting your query here at techyv.com
Best regards,
