Is ASUS a good brand for laptops or tabs? What technology does ASUS use? How does it compare with other brands? What are some of the key features and specifications of an ASUS laptop costing between $500-700? How about the battery life, hard disk capacity, RAM and processor technology? Which operating system does ASUS support?
Is ASUS A Good Brand?
Asus iss just an excellent brand, I own Dell venue pro 8 and it is truly amazing, High quality device, Asus uses high quality technologies like every brand, such as Intel processors, you can add 100$ to your budget and buy the powerful Asus Vivobook V551LB-DB71T, It is amazing beat for just 800$, It packs Intel Core i7-4500U 1.8 GHz processors,1 TB 5400 rpm Hard Drive,8 GB SO-DIMM RAM and Nvidia G740 Graphics The screen size is also satisfying 15 inch
But if your budget is tight you can go for ASUS A53E-EH71 with 15 inch screen, i7 processor, 4 gb RAM and 500 GB hard drive
