zoegordon
Posted on - 02/27/2012
Hi all,
I have an Asus K52F laptop, which is running on Windows 7 Ultimate. This is a new computer and I have neither used nor opened its webcam until now. The software for the webcam on my computer was not available initially but I eventually found it online. I downloaded the USB2.0 UVC VGA webcam software from SONIX and a couple of other sites but they all failed to work for my webcam.
The websites of the computer manufacturer of the software and/or drivers may be different from what I currently have, but they used to work in my old laptop/webcam.
Can you, guys, help me out? Any help will be greatly appreciated. Thanks in advance.
Asus laptop webcam not working on Windows 7 Ultimate
I think the problem you are discussing is that your webcam is not working right have you checked on Skype or any other video chat software? Is it working or not? I think the software you are using is not confine with the webcam you are using. One thing more which I should discuss here is that you should update your driver.
1. Follow these instructions in order to work your webcam.
2. Go to the driver options and then update the driver using internet when you connected to the internet then click on update it will automatically update to the software which is required by the webcam. And then use software's whatever you want to use your webcam in any way offline online.
kamni
Windows doesn't need drivers to detect Plug and Play hardware. And your problem seems to be the webcam hardware is no longer detected!
You might double check BIOS. Make sure there's no option that it's disabled there (Disabled in BIOS would prevent h/w detection)
But we can also double check a couple things
1. List any Problem Devices
Make sure devices are connected and powered on.
Click Start->Run, enter: msinfo32. Click the + sign next to Components to expand it.
Click Problem Devices. Anything appear?
If yes, click on it, Ctrl-A to select all, Ctrl-C to copy it, Ctrl-V to paste into next post.
On the other hand, if no devices are listed, tell me so.
2. Let's see what device/driver data is still loaded into Windows. See How To Report Your Computer's Device Manager Data
/* EDIT */
btw… Your webcam will almost certainly be a USB enumerated device (it's Hardware ID will begin USB ). I'd also venture to guess those Base System devices you saw were PCI devices?
If the built-in webcam on your laptop doesn’t work after installing all the drivers you found from other websites, that’s because none of those drivers are compatible with your camera. If your laptop doesn’t come with a CD that contains the drivers, there should be no problem because you can always download it from your laptop manufacturer’s website.
To download the driver for your webcam, go to ASUS K52F Driver & Tools. Here, select your correct operating system to display the correct software for your laptop. Since you have Windows 7, check whether you have the 32-bit or the 64-bit version. Selecting the wrong version will still not make the camera work. This will display all the available software for your machine.
Download and install all the available drivers for your laptop. This should fix the problem.
