Asus N61jv – webcam problem
Asked By 250 points N/A Posted on -
I have an ASUS N61Jv, running Windows 7 Professional 64bit (legal, pre-installed).
The built in webcam is suddenly not functioning anymore. I can't recall changing anything, so I'm not sure why this is happening. When opening the cam in skype, windows live messenger, or lifeframe3, it keeps saying that the cam is in use by another application. I've reinstalled the driver, but to no avail. I have also reinstalled the software programs. Could anyone help me out with this? Thanks for any help!
Here's some information:
USB2.0 UVC 2M WebCam
USBVID_13D3&PID_5122&REV_0202&MI_00
Best Answer by Nazmi
Answered By 0 points N/A #112923
Have you lost your webcam installation CD?If not happen you could put the CD into CD drive and wait for webcam drivers installation.The installation is begin.You shall find webcam drivers name AMCap.After the driver installation you would click in the driver name icon.A demo version of AMCap drivers will appear.Click on it.The webcam face should be towards you then you would be capable to see you yourself.Unless the drivers is uninstall you couldn't see anything else.Select File.Then open folder. See devices,options,capture,window and help.;You can click help.
Answered By 0 points N/A #112924
I have absolutely same problem with my ASUS N61Jv, as described above.
It happened after a driver update for WebCam. WebCam was too slow for example in Skype video, I downloaded the official  webcam driver for this notebook. Now cannot use the webcam at all:  """" it keeps saying that the cam is in use by another application.
Can some one help?
Answered By 590495 points N/A #112925
Since this is the status of your webcam, I think there is already a problem with the device’s driver. But first make sure that your computer is not infected or something since the webcam is somewhat busy all the time. Update your antivirus then run a full system scan on your entire hard drive.
If the result turns out negative for any infection, try visiting your computer’s official website and see if there is an available driver there for your webcam. For branded computers, its website always has the recent drivers for their different computer models. If there is an available driver for your built-in webcam, download it in a folder.
Next, uninstall your webcam’s driver then restart your computer. After booting, open Windows Explorer then navigate to the folder where you save the installer. Double-click the file to start the installation. See now if this driver will work on your webcam. If not, try restoring your computer to a previous state where the webcam is still working.
