The Asus Zenfone 2 ZE551ML Verses Samsung Galaxy Tab S
Comparing the Asus Zenfone 2 ZE551ML model and Samsung Galaxy Tab S model, which of these two mobile devices stand out in terms of design, display, software, performance, camera, battery life and above all value for money? What are some of the interesting features that are common between them? Caleb Sinkala Mbia is my name and a student of a popular university in West Africa.
Answered By 5 points N/A #131773
There are many differences between Samsung Galaxy Tab S and Asus Zenfone 2 ZE551ML. This distinction differs from OS to hardware.
Samsung Galaxy Tab S comes with Android Kitkat v4.4.2, upgradable to Lollipop, and available 1.3 GHz, 1.9 GHz and 2.3 GHz processors. Its RAM space is 3GB, quite enough for running tons of apps at the same time and perfect for smooth gaming with heavy games. Its screen size is 10.5 inches, large display with awesome graphics quality, supporting 2560 X 1600 pixels with 288 ppi.
Asus Zenfone 2 ZE551ML comes with Android Lollipop v5.0 and available in 2.3 GHz and 1.8 GHz processor. Its RAM space varies from 2GB to 4GB. You can choose the RAM size depending on your working method. Its size is 5.5 inches with 1080 x 1920 pixels resolution, 403 ppi.
By judging all these factors, Asus Zenfone 2 ZE551ML seems to be more flexible as you can choose its hardware based on your budget. It can be used for both heavy and normal usage and it comes with Android 5.0, giving more advantage than Galaxy Tab S.
On the other hand, Galaxy Tab S is a nice choice for those who want a large display for better work. All other facts match almost with Asus Zenfone 2 ZE551ML, so there’s not so much distinction between these awesome smartphones.
The full specs of Samsung Galaxy Tab S and Asus Zenfone 2 ZE551ML can be found. Finally, it’s your choice which you will buy.
