john_lord
Posted on - 10/01/2011
I used Atego Cloud Backup and gladdy saves all my data from multiple connections and it become centralized backup. I want to change my Operating System from my previous Operating system windows 98 to Windows XP1 version 2002, does my data lost if i change my Operating System?. And if data are saved is there a possibility one of my data will be missing?.
Landon
Atego Cloud Backup Windows OS Compatibility
Thank you for your question. You can actually change your operating system in a safe way without getting your data lost. We have to make sure that the files will be saved before you change Windows 98 to Windows XP. There are actually two ways to solve it. First, you can purchase or download a software that can transfer your files from the former operating system to your newer operating system.
Go to http://web.laplink.com/product/pcmover-professional/ pcmover-professional-8 order the software. Follow the instructions on transferring your files. Secondly, you can transfer files manually before you can change the operating system. Save all your files and make a backup for it using external drives and other media storage. I hope these answers can help you solve your problem.
Thank you.
