Alen_park
Posted on - 08/26/2011
I'm using 512mb ATI Raedon graphics card, with all the update drivers.
I have recently updated it, but my Catalyst Control Center is Not Opening anymore.
When I try to open it from the Desktop, Nothing happens. Neither any Error message, Nor it opens.
I have reinstalled the Catalyst Control Center, but nothing happened. I'm using Windows 7.
Please help me, How to fix this?
ATI Catalyst Control Centre Not Opening.
Since you are using windows7.
Try to go to the directory of the file and locate the .exe or application then right click then run it as moderator or check the box that says, default run as moderator on all users.
This should open the program.
You will need to check the check Device Manager, and from there check if there is a warning or disabled marker next to Display Adapters that signifies that the drivers have not yet been installed. If that is the case, then you will need to completely uninstall the drivers – you can use the ATI driver Cleanup utility on their site to remove those drivers completely. You can as well try using Driver Sweeper to remove drivers completely.
Once you have done the above, you will need to reboot the computer, and then check the device manager again. In case you still have the warnings, then it will be because the drivers have not installed correctly, and therefore you will need to reinstall the drivers.
-Clair Charles
