ATI Radeon HD 5770 over clocking
I have a video card ATI Radeon HD 5770 with 850 MHZ GPU. I want it to increase to 900 MHZ so that my graphics card wont burn out quickly. So please suggest me a way to over clock it & any powerful cooling unit you want to suggest.
Thank you.
Best Answer by Huxaifa
Answered By 0 points N/A #102904
Use ATI's own catalyst graphics driver to over clock your GPU from 850 to 900 MHz. Since ATI's overdrive utility provide you with plenty of options. After setting the speed of your GPU, do remember to set your fan on auto, so that the fan speed rises with your GPU temp.
It'll run safe at 900 MHz without burning your card, as ATI provide maximum scale of 960 MHz, you can over clock your GPU up to 960 MHz safely without needing a cooling unit. But I'll suggest you to over clock it up to 900 MHz for a safe end. For your satisfaction you can use Cooler Master V 10 cooling unit.
