ATi X800 AiW Capture Problem with UleadVideoStudio 9
Hello Pro,
When I try to capture the video in Ulead Video Studio, I ended up with an error message. The real problem triggered when the press the stop button in the video capture, it throws an error saying ‘the file created is corrupt and unusable’. I get this error message even in the windows moviemaker too. I tried to trap the error, but I cannot. Help please. Thanks in advance. Please help.
Ulead VideoStudlo
Capturing failed.
The file created is corrupt and unusable. It will be automatically deleted.
OK
Answered By 590495 points N/A #187527
If this error also happens even when using Windows Movie Maker then there is probably something wrong with your hard drive. You can check your drive for error using Windows Scandisk and possibly fix some problems. Click Start, Control Panel, Performance and Maintenance, Administrative Tools, and double-click Computer Management. In Computer Management under Storage, select Disk Management.
Right-click on drive C and select Properties. Go to Tools tab and click Check Now under “Error checking”. Check “Automatically fix file system errors” and click Start. Wait until it is finished and restart your computer. See if the error appears again when using Windows Movie Maker. If the problem continues when using Ulead VideoStudio, try reinstalling it.
Uninstall it then click Start, All Programs, Accessories, System Tools, and select Disk Cleanup. Select drive C and click OK. Check “Temporary files” and click OK. Wait until it is finished and restart your computer. Install Ulead VideoStudio again then run it. See if it works. You may also try upgrading your operating system to Service Pack 3.
Download the upgrade pack from Windows XP Service Pack 3 Final Softpedia or Windows XP Service Pack 3 Microsoft. This updates your operating system with all previously released updates.
