Jamin Ywain
60 points
Posted on - 12/02/2012
Hello Friends,
Does anyone know why the following error occurs when I try to and run atiwinflash, it says
Can't erase ROM
There is a problem in ATIWinflash that the software can not erase ROM.
Any solution?
Thanks in advance.
ATIWinflash
Cannot erase ROM
ATIWinflash – Cannot erase ROM
The problem occurs due to a combination of problems between your BIOS version and software. You better be sure about your BIOS version and software version. If they are correct, then you can try to solve this problem with another software such as TechPower.
You can download a new version of WinFlash, which is compatible with your BIOS system.
There are many utility softwares that call memory resident tweaking utilities such as RivaTuner, which can solve also solve the BIOS problem
. If you only want to use WinFlash, first, restart your computer and reinstall the correct version.
