I need att the communication manager for iPad to transfer files from iPad to the other devices like laptop. I need a good URL to download att the communication manager for iPad.
If anyone knows about it give me the URL.
Att communication manager for iPad
The AT&T Communication Manager is user-friendly software that helps you to supervise your link to WiFi networks and to the AT&T mobile information network.
The type features are: easy installation and instinctive user interface admission to our 3G networks, EDGE and roaming associates’ networks, where appropriate, offers simple verification at AT&T WiFi hotspots for clients who meet up definite eligibility conditions.
Download here:
Best regards,
Heather marie
Whether you are using a PC or a Macintosh, you can easily transfer your iOS device’s contents to your computer by synchronizing your phone with your computer using iTunes. When using iTunes, make sure you have the latest version installed. Go to the Update to the latest version of iTunes page and select the device you are using.
Like if you are using a PC, click the “PC” link and for Macintosh, click the “Mac” link to download the version specific to your device. The latest version of macOS is 10.15 Catalina. If you can’t update your Mac to this version because of hardware limitations, you can update iTunes up to iTunes 12.8.
To update iTunes on your Mac, open the App Store then click “Updates.” If there are any updates available to iTunes, click “Install.” For Windows users, if you have Windows 10, you can download the latest iTunes on the Microsoft Store or visit the iTunes Download page on the Apple website.
