Attaching Nikon Coolpix s9500 to tripod
I recently got a digital camera Nikon Coolpix s9500 but I am impressed with the video quality. I have also seen people putting camcorders on tripods. How do you choose a tripod that fits perfectly. As you tell me that also include where to buy them.
Best Answer by Wagner Desantiago
Answered By 0 points N/A #170728
Hi Larry Montelongo,
You can check this site, they sell camera accessories which is compatible with your Nikon Coolpix S9500. The TRIPOD DELUXE (which is on the link) extends up to 1400mm and weighs 1025 grams. And according to their site, it will cost you € 29.99 including tax. They accept payments thru online such as PayPal. I hope this tip will help you.
Martine Paul
Answered By 5 points N/A #170729
Hello Larry,
Yes there are a lot of tripods out there to try for your Nikon Coolpix s9500. But I would recommend you to get Nikon Coolpix s9500 flexible tripod. This is a top rated product and easy to set up. And its price is also reasonable. You can get it for only 13.47$ at Amazon plus free shipping.
Features –
  • Flexible and not so long.
  • For compact digital cameras and camcorders.
  • You can use this for any Digital cameras apart from your s9500
  • A quick release plate for swift and easy mounting as well as dismounting.
  • A safety knob lock for the mounting plate
  • The joints are flexible and rotate 360 degrees to conform to any shape
  • Rubber rings and foot grips for extra gripping power and secure hold.
Buy Tripod for your Coolpix here.
Hope it helps!
