Luz M Terry
35 points
Posted on - 04/16/2014
Hello there,
I try to burn an audio CD but always I have the same error, this one. I am tired of this error and please can someone help me to burn an audio CD and help me to solve this ? I did some researches in the Internet and nothing help to solve this ? Why I have this error ?
Thank you !
The attempt to burn a disc failed. An unknown error occurred (4450).
points
The attempt to burn a disc failed an unknown error occurred (4450).
To work around this issue is not so easy.
The first solution is to update to the latest iTunes because older version contains bugs that might do such issue. Download iTunes.
Also, update your firewall, security software, router and other driver to the latest version.
If still not fixed, there might be some issue with your iTunes installation inside your PC. To repair the installation,
Go to Start menu >> Control Panel >> Programs >> Programs and Features.
Right-click on iTunes and select “Change/Remove” to uninstall it completely.
Then, download the latest installer and install it.
If still no luck, it indicates to a hardware issue with your hardware, for instance, your CD-ROM or the CD/DVD you’re trying to burn. Also, registry issue might be the cause of this problem. Download and scan your registries with any good registry doctor, say, Wise Registry Cleaner.
