I need help removing metadata from avi files. Can I edit the metadata that is within the avi files with any kind of software? Something similar to tag and rename but aimed more towards video and avi files?
Attempt at removing metadata from avi files
Hi Timothy,
You can use abcAVI Tag Editor to view and edit video tags in AVI format. It will allow you to get some information on video you want from the Internet Movie Database or you can type it by saving the information in the AVI file. It will also allow you to edit titles, subjects and more than 40 tags to your video.
You can also use VLC Media Player. You can edit metadata using VLC by going to Tools > Media Information then you can now change all metadata.
