An attempt to resolve the dns name
This is error report I get however I try to connect to my servers sphere which I just set up today. I read through a group of other gear on the same error message, but each of them has had dissimilar solutions and none of them have helped me.
One of them is  thing that I think is related to my trouble is that I can't ring my domainon the W7 computer I try to connect. I can ping the server, but not the domain. The domain I use is set up similar to "domain. Local.
Answered By 0 points N/A #185495
Log into your Router get the actual DNS IP address. 72. X.x.x numbers. Server in DNS, you want to put the forwarders to those 72.x.x. numbers. Your server's static IP address should be 192.168.1…013, subnet 255.255.255.0,. Gateway 192.168.1.1, and DNS server should be 1920.168.1. X (point to itself, the server's IP).
Your W7 package will be your IP address you allocate (192.168.1.10???), Sub, 255.255.255.0. Gate way: .192.168.1.1, DNS 192.168.1.1
inner private network that DNS point to your Server's IP address. For the gateway, your internal net will point to your router's IP tackle. For private networks name resolution you point to your server hosting DNS. Since the internet first name resolution (websites) your DNS server will have forwarder’s pointing to the 72.x.x.x. Figures (public DNS servers).
Host:.
IP: 192.168.1.3
Gateway: 192.168.1.13.
DNS: 192.168.1.3.
DNS Server setting
Forward: add 72.xx.x Systems
Win7 Box:
IP: 192.168.1. x
DNS: 192.168.1.13 & optional 72.x.x (for straight website declaration if you want a less important.)
