Attempting to revise a Joomla 1.7.5
Hello to all!
I have been attempting to revise a Joomla 1.7.5 site to 2.5 using the instructions but an error notification is pop up like this:
JInstaller: :Install: Error SQL DB function failed with error number 1146
 Table 'overcome_oosite.e3qvb_redirect_links' doesn't exist SQL=ALTER TABLE e3qvb_redirect_links MODIFY old_url varchar(255);
 SQL =
 ALTER TABLE hfps_redirect_links MODIFY old_url varchar(255);
 Files Update: SQL error file DB function failed with error number 1146
 SQL =
From the analysis till now, it does seem to have customized to 2.5 – but I want to confirm this error doesn't indicate I might have any problem that require me to take care of! Did any of you face this problem before? If yes, then please share your experience and suggestions. It will be really helpful for me.
