Attempting to tradition build script and I received an error message
I am exercising IDL version 8. I am attempting to tradition build script and I received an error message. If somebody has an idea to solve this please share. Thanks.
Error caught Attempt to call undefined procedure/function: “Xmanager” Execution halted at : TT_LOGON
Error caught
% Attempt to call undefined procedure/function: “Xmanager”
% Execution halted at : TT_LOGON
%  TECHTIP70
%  IDLRTMAIN
%  $MAIN$
OK Cancel
Best Answer by Stephen R Gates
Answered By 50 points N/A #170948
Hi EarlLShryock,
You are receiving an XMANAGER error. The purpose of the XMANAGER is to provide the main event loop as well as management for widgets created with IDL. XMANAGER takes control of event processing with a widget program. The IDL widget application blocking is enabled by default and it will block all other processing. So keep in mind to create applications that coexist with the IDL command line.
Answered By 65 points N/A #170949
Input the profile name you use when you sign into Windows. You received a command in the location but sadly that command is not in the location. Or, it could mean that you downloaded a corrupt file, so better for you to download a new one. Another option is for you to reinstall the software over and over again. It will help.
