Here is my situation, while I attempted to upgrade to 6.05, I noticed an error message which has been illustrated here. I could not identify how "it probably has been updated", is expected to assist me. It hasn't been modified till now. After that I run Ms Windows specialist. I've attempted to activate the upgrade as the Manager. I cannot come up with any more thoughts. It would be very helpful for me if you can kindly suggest anything about the further steps.
I am looking forward for your reply. I would like to thank you in advance for your time and help.
Installer Information
String applying patch to file C:Config.MsiPT3010.tmp. It has probably been updated by other means, and can no longer be modified by this patch. For more information contact your patch vendor.
Attempting to upgrade to Steinberg Cubase 6.05
It seems that the upgrade that you did on Cubase didn’t go so well. Try restarting your computer then try applying the patch again and see if it will succeed. Since you already have the version 6.05 of Cubase, might as well do a clean installation of the program again to restore it to its default configuration and remove possible corrupted files on its installation that is probably affecting the whole process. Uninstall your current version of Cubase then restart your system when asked.
After booting, check your computer for any possible errors. Use a disk utility application to check the system. Install Cubase 6.05 after this and see if it works.
Since version 6.05 is an older version of Cubase, why not try upgrading it to the latest version. Cubase 6.0.7 is the latest release and is already available for download. This version works on Windows 7 both 32-bit and 64-bit, and Macintosh OS X 10.6-10.7 platforms. To download this latest release, you may visit Cubase 6 Updates.
