Last week, I downloaded Audacity 1.3.9 and up until now it is not functioning properly.
Absolutely nothing happens whenever I click on the icon on my desktop.
I uninstalled the program and re-installed it again but to no avail.
I think some components of the program can be found throughout the computer.
Can anyone please help me?
I don’t know what to do.
Audacity 1.3.9 not functioning properly
This may because of excessive memory use arising in your system when you open the software so this results to slowed launches as well as crashed application. See if you meet the system requirements for the version of the audacity.
It is better if you have higher resources on your system so that you will not be having hard time in using it.
Read readme.txt so that you are aware of the bugs still unsolved.
The table shows the system requirements of audacity 1.3.9.
Windows version
Recommended RAM/
processor speed
Minimum RAM/
processor speed
Windows 98, ME
128 MB / 500 MHz
64 MB / 300 MHz
Windows 2000, XP
512 MB/1 GHz
128 MB/300 MHz
Windows Vista Home BasicÂ
2 GB / 1 GHz
512 MB / 1 GHz
Windows Vista Home Premium/
Business/Ultimate/7 (32-bit)Â
4 GB / 2 GHz
1 GB / 1 GHz
Windows 7 (64-bit)Â
4 GB / 2 GHz
2 GB / 1 GHz
Windows Vista / 7 are not supported in Audacity 1.2.6.
