m williumm
10 points
Posted on - 04/07/2013
Hi, my brother is using Alcohol video convertor on his Lap. But sometimes when converting Audio files on Alcohol convertor it gets some errors like staking. Is there any audio converter plugin for alcohol to install and solve this problem. Please can you suggest me some any other ways also to solve this problem?
Audio converter Plugin for alcohol to install
Follow the steps below to use the Alcohol Audio Converter correctly:
1. Go to Device in Alcohol 120% and then select the Audio Converter. For latest versions, choose the icon under the Main option.
2. It will launch the Audio Converter.
3. Insert a disk to your optical drive. The converter will then connect to FreeDB.org to identify the album where it will be listed.
4. If you want to rip the entire disc just simply click Select All or if you want to rip specific tracks, click on the box and select them and then click Rip.
5. The disc will be ripped to your computer.
6. When done ripping, the window that appears with the percentages will close.
7. Close the Audio Converter.
