Audio Icon on my task tray marked with red X
20 points
Posted on - 08/05/2011
Audio Icon on my task tray marked with red X.
I have installed a new Microsoft Windows 7 Home Edition Operating system. I installed everything including my motherboard drivers. All hardware works fine but after updating the operating system through the Microsoft Windows Update, my Audio device doesn’t work anymore.
It shows a red X on the task tray Icon. And if you mouse over it, a tool-tip shows “No Audio Output Device is installed”. No System Restore point because I disabled it. I re-install the driver but no luck. I am pretty sure that I got a solution from you.
Thanks
