arturo owen
10 points
Posted on - 02/25/2012
I am trying to make a presentation in PowerPoint. I have put two songs there but when the first song started it never stops though the second one starts playing. I have used trim audio in that presentation but its not working. I want the 1st song to stop when the second one start.
Please help me to do this.
Audio problem in MS PowerPoint
Hello Arturo
I have read your issue regarding the PowerPoint presentation and i think you can use the option to stop the first sound after the next slide or after several number slides has been click then start playing the next song. To access this option you need to go to Animations tab in PowerPoint and click on the custom animation button on the page. Then a custom animation page will pop up on the right side then you can go ahead and right click on the sound and choose effect options. You should be able to see the stop playing menu there. Hope this helps.
