john joseph
40 points
Posted on - 08/15/2011
Hey there.
I have installed skype on my computer yesterday but i have like a problem with my audio setting. I can hear the other person on the other side but they don't hear me. I've looked everywhere even changed from headset with a friend and still got the problem. Can someone point me in the right direction please?
Audio problem with skype, help please.
Sometimes this type of problem occurs in Skype. This might because of the connection of your internet. Slow internet sometimes occurs this kind of problem. If your internet is fast enough then your sound driver must have some problem. You can re install your sound driver from your motherboard CD or Soundcard CD. Or you can download your latest driver from the internet. Install it and test your voice in skype. There is a option or automated function that can test your voice. Its name is Echo/Sound test service. If your skype is older version then download a latest version of your skype. I hope you have got your answer.
There can be many reasons for this problem and you can solve your problem by going through these points.
First of all check your internet settings.
Open Skype and call on echo / sound test service and make sure you are getting your own voice in there.
Make sure your microphone is working properly.
Make sure that you have not turn off your microphone in call settings.
Make sure the signal quality for your call is perfect.
Check for all settings available for voice chat over Skype.
Once go through these steps you will be able to solve your problem.
