Audio Video and graphic software Required
I have a gateway dual core system, I want to install audio video and graphic driver, I am having problem in finding the software please help me in and solve my problem.
You did not include your Gateway model and Operating System so we can provide specific solutions. Good thing Gateway has a support page for downloading drivers needed for your computer. Just visit this site:
http://www.gateway.com/worldwide/support/
Select the Support tab and click Drivers and Downloads. Click the "Change selected product" link. The Select your Product window will appear. Choose from the Category depending on the type of your Gateway machine. Select Desktop if you are using a desktop PC. Select the Series of your PC and then select the Model.Â
Click Confirm if you are sure that you have entered the correct Gateway machine. All the drivers for your selected device will be shown on the screen. Just click the download icon to download the driver.Â
It’s not problem at all try to downloaded from:
Or
There a lot of site have free download for this programs.Â
