Audiobook slicer software that is free and compatible for Mac.
Audiobook Cutter is a user-friendly tool which slices or splits huge MP3 podcast and audiobook files into lesser ones without re-typing.
The major function of this MP3 splitter is to construct audiobooks more convenient in a easy to use way.
Get a free download and a paid upgrade available at this site.
Best regards,
Heather marie
Hi, Orlaandoaddison
Cutter hand second Audiobook is often a user-friendly tool that in turn sliced or maybe massive forged audio pod splits and also files audiobook in versions without having to retype follow-up.
The particular major function of this audio splitter is usually to create audio books much easier within an easy to use way.
You will be to get free one from here:Â
Hope you will get your result.
Thank you.
