Hello experts,
I have few Audio Books which I stored in my Purchased folder. The problem is, I can't sync these Audio Books to my iPhone. If I try to drag those books to iPhone, it gets stuck and I will need to restart my device. I tried for few more times but it always failed with the same result. So I want to ask anyone of you to please help me in syncing my audio books to my iPhone. Thank you.
Audiobook Sync went wrong on Apple iPhone
Successful syncronization of your audiobooks with your iPhone depends on the method being used. One simple option for most ways, considering your iPhone seems to freeze is to try to synchronize your audiobooks in parts and not all at the same time.
Nevertheless, in order to avoid crashes, perhaps the best way to sync would be through the iTunes Library. However, and if you have all the files available, you can simply connect the system where you have the files on (assuming it’s not the iPhone itself) and copy them.
No matter which method you use, you should try to pass them some at the time, instead of the whole folder.
