Nelsson
Posted on - 12/10/2011
Hey,
My sister gave me her laptop Toshiba windows XP pro. On it I have installed Virtual DJ home. A few days ago my laptop shut down (my battery was low). When battery was recharged after starting up laptop I’ve received error message. How can I fix this problem? Any suggestions are welcome.
Thanks in advance
Nelson
AutoIt Error
Line 0 (File “C:Program FilesVirtualDJrunVDJ.exe”):
$Line = _StringToHex( StringStripWS($aRecords[&x], 3) )
$Line = _StringToHex( StringStripWS($aRecords[^ ERROR
Error: Array variable subscript badly formatted.
OK
AudioIT error Line 0 (File “C:Program FilesVirtualDJrunVDJ.exe”):
Run the Virtual Dj home from direct path.Go to drive C then go to program files and open the folder Virtual Dj folder and run it from there.
If it still shows the same error then what you have to do is first install version 5 and then if you do not have an XML database file you have to rename your existing Database file.Now check it will surely run then go back and run VDJ.exe application
If you got the same error then the folder must be corrupted,its not working because some files has been corrupted from the current installation,you have to reinstall the Virtual Dj.
That error seems to be from VirtualDJ. If you receive that error after booting, it means the application is configured to run with Windows and the error indicates that the program is not working properly. If the error started after your computer suddenly shut down due to low battery, it means that sudden shut down corrupted the application. To fix the problem, try to uninstall and reinstall the program.
Download the free version of Revo Uninstaller and install it. Once installed, start Revo Uninstaller then select your VirtualDJ among the applications and click “Uninstall”. Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer.
When it is finished, close Revo Uninstaller and install VirtualDJ back. See if this works. Also, since VirtualDJ is free for home use, try downloading the latest version instead. Go to VirtualDJ Software Download to get the latest. The latest version at the moment, VirtualDJ 2018, supports Windows 7, Windows 8.x, and Windows 10.
For Mac users, it supports OS X 10.7 Lion, 10.8 Mountain Lion, 10.9 Mavericks, 10.10 Yosemite, 10.11 El Capitan, 10.12 Sierra, and 10.13 High Sierra.
