Hello expert, I put some audit program files to my USB disk. When I put the USB stick into other computer the files are not shown. Please help, is the problem is on a USB stick or audit program file. All other files are shown properly.
Audit program files to USB disk
If the issue occurs after you put the audit program files on your USB, then this might be the issue. Try removing it again and see if you can access all your files again.
Anyway, does the Audit program files that you put on your USB was intended to audit your system? I mean, is it a software that you installed on your USB to audit your computer system?
IF this is the case, you can try to use another auditing software. Try the SIW or the System Information for Windows. It will let you perform your PC configuration and will give you a detailed information and more.
To create a System Auditor on your USB, follow the steps below:
1. Insert your USB on your computer.
2. Download and save the SIWÂ on your USB.
3. Download autorun.inf file and save it on your USB.
4. Remove the USB and you can now start the auditing in your system.
