Hey everyone
I am familiar with Arturia Minimoog V sound filter. It is a native and virtual sound filter and it uses more CPU overhead.
I need some filter which is as efficient as Arturia Minimoog V but uses less CPU overhead.
Can anyone help me?
Authentic sound is needed from sound filter.
Hi Wayyne,
You can use the most popular sound filter program the AC3 Filter. It allows you to adjust sounds and mix it with a sophisticated audio and process filter. It has a functionality wherein you can monitor the CPU usage and input and output levels. Please click the link below to download it.
AC3 Awesome Sound Filter Program
In addition, I also included a list of the Free Sound Filter Program where you can also try.
Must try awesome List of Sound Filter Program – This is the list of cool and unique sound filter program which you can try. Kindly review each of it and use it according to your needs.Â
Ware
